Old 05-06-2014, 08:15 PM
hot rodder's Avatar
hot rodder hot rodder is offline
Default new whizzer tach can you use on any 4 stroke
I bought a whizzer tach off ebay would any one know the wiring diagram and if it works like any analog tach. If it does i should be able to wire it to my 4 stroke by using the ground wire on coil for the tach lead and positive wire to 12 volt and negative ground. any input
