Thread: Progress
Old 05-05-2014, 01:39 AM
mapbike's Avatar
mapbike mapbike is offline
Default Re: Progress
Originally Posted by Toothy View Post
Map / 2 door you make a lot of sense, can you by the bits a home depo store or somewhere more specialized?
Search drill bits and get a set of the wire gauge bits that measure in size from 80-61 and you need a pin vise to chuck the bit in which is cheap there on the site, around $10 for the whole set up and you'll have what you need to fine tune your carb.
My elevation here is 1240' above sea level and either a jet frilled with the #72 or #73 wire gauge bit tunes my NT carbs good for my set up, I'd probably start with a #72 since its common to have a #70 as the stock jet size, with wire gauge bits the larger the number the smaller the bit, a #73 is smaller than a #70 and so on.
