Old 04-30-2014, 08:28 AM
bluegoatwoods's Avatar
bluegoatwoods bluegoatwoods is offline
Default Re: HELP! My NEW bike wont start
Why don't you start by verifying spark. Trace the wires from the magneto to the CDI to the spark plug. Make sure that these wires have not come loose and are connected properly.
If that all checks out, then remove the spark plug and hook it back up to the spark plug wire. Lay the spark plug threads against the engine and spin the back wheel.
You should be able to see the spark at the tip of the plug.
If this checks out, or if it doesn't, come on back here with that info and there'll be someone around who can steer you from there.
