Thread: New Bike Build
Old 04-27-2014, 08:12 AM
LR Jerry's Avatar
LR Jerry LR Jerry is offline
Default Re: New Bike Build
Originally Posted by Gravity View Post
Here it is all complete Okay maybe not all complete but just about. I need to get a back brake since I had to remove the back disc brake to allow room for the sprocket. I also had to use a hole saw to make the opening on the sprocket larger to fit around the disc brake mount on the wheel. The front disc brake seems to do the job, but Im still going to hook up a v-brake on the back just to be safe. It rides nice and smooth just like I hoped. These things are awesome!
Also if anyone has a solution for this gas tank, Id appreciate it. I couldn't find another place for it. Its mounted on top of the wires to shift gears on the bike, so im stuck in one gear. I have it in the best gear for pedaling and wont be doing any shifting since theres a motor on the bike but would like to solve the problem just in case. Thanks
Is your bike a 21 speed or a 24 speed? Then I can tell you the best shifting system for it.
Land Rider Jerry
