Old 04-25-2014, 12:40 AM
Theon Theon is offline
Default Re: Bought bottom end from Boy Go Fast, should I be worried?
Easiest way is to measure from the main bearing pin on the crank to the edge of the big end pin.
4mm means you have a 40mm crank, 3mm has you a 38.
