Old 04-22-2014, 10:19 PM
mapbike's Avatar
mapbike mapbike is offline
Default Re: Engine vibrations, not from mounting
Ill agree it does sound like you have an air / vacuum leak, make sure the carb is pushed up tight on intake tube and for sure che k to be sure the gasket between intake and cylinder is good.
I had one engine do the same thing and on mine it was the crank seal under mag rotor, hopefully your leak is a simple gasket and not the seal.
Best wishes.
