Thread: Lost a part
Old 04-19-2014, 10:16 PM
mapbike's Avatar
mapbike mapbike is offline
Default Re: Lost a part
the hole in the washer is the critical part, if the hole in what you use is to big then the C-clip that is on the needle will slide through the hole in the washer and allow the needle to rise out of place, anything that is large enough around for the spring to press against and has a hole/slot small enough that the C-Clip cant get through it will work, if you have some tin snips you could make one out of a piece of a tin can lid or any other similar thickness flat steel.
