Old 04-09-2014, 09:51 PM
maniac57's Avatar
maniac57 maniac57 is offline
Default Re: Resistance while clutch is pulled
If the chain is not binding in the case and the wheel stays stationary when lifted off the ground with the clutch pulled yet sometime slides on gravel, then it has to be a rear wheel or chain issue. Something is creating drag. Normal chain drag is nowhere near strong enough to drag the wheel in gravel.
