Old 04-09-2014, 05:12 PM
Sylph's Avatar
Sylph Sylph is offline
Default Re: Resistance while clutch is pulled
Originally Posted by Greg58 View Post
It sounds like the cable adjustment is not right if the rear wheel slides with the clutch handle pulled in, if the clutch is adjusted correctly it should roll with out sliding the tire. Pictures of the clutch cable at the engine might help with a solution.
If you read my original post carefully, you'll see that I mention that I've already tried that, but thanks for chiming in.
