Old 04-09-2014, 04:55 PM
Greg58's Avatar
Greg58 Greg58 is offline
Default Re: Resistance while clutch is pulled
It sounds like the cable adjustment is not right if the rear wheel slides with the clutch handle pulled in, if the clutch is adjusted correctly it should roll with out sliding the tire. Pictures of the clutch cable at the engine might help with a solution.
Your results may not be the same,Greg
