My wife was, at first, incredulous as to why I needed a scroll saw. I explained some of the various and sundry things it could do. I could tell she was softening up, but wasn't there yet. So I then told her it would also help me do welding.
"Welding?" she repeated, looking over the top of her glasses.
Yes, I explained, because the guy down the street from us expressed an interest in borrowing the scroll saw and, in return, agreed to let me borrow his old stick welder to practice with once he doesn't need it on his site. A man's access to tools is very often greater than the amount of tools he, himself, actually owns. Tools are sometimes like "Man Money", or "Man Collateral"; when you don't need the certain tool at that precise moment, you can trade it to a trusted neighbor in barter for a tool you need. Thus, you expand your "Usable Tool Base".
I'll never quite be able to interpret that next look she gave me. But at least she didn't say anything else.
A/R its funny how that works, one of the men I work with has borrowed my utility trailer several times to move and for use around his place. He last week bought a tractor with bucket and box blade and offered it to me to use anytime I need it. Sometimes helping others with things comes back to you in a good way.
When I have no access to a mill or lathe, I perform small miracles with an angle grinder and a drill press
And never underestimate the power of a Dremel tool![]()
Welcome to the brotherhood Dan. As 2Door said, not a big fan of HF machinery.
You need to learn basics like: Tramming in the vise or angle plate or what ever you have set up on the table. You will need to know basic math, and some geometry and trigonometry too. You will need a couple of magnetic bases and dial indicators, a .0005 test indicator and a indicoil. Do you have a tooling kit? If not you will need collets and a drill chuck, some end mills, machine wrenches, and a strap set to get started.
Never climb mill (your not experienced enough) always cut with your tool cutting towards and into the work surface, pushing against the cut.
When moving to a desired stationary location always move the table and saddle dials in a clockwise direction even if you have to pass the location in a counter clockwise direction and come back to it in a clockwise direction. This will help keep the table and saddle from jumping when your cutting tool makes contact with the work surface.
Use the table, saddle, and head locks to secure your location or to create a little drag in the movement. There is no need to torque down on the lock levers. Just a little push should do. Keep your machine clean and lubricated, don't over load it and it will last you a life time.
Keep your fingers and face out of the cutting area. Remove all jewelry. If you have long hair tie it back and wear short sleeves. Let the tool do the cutting forcing it will only wear it out faster. Use a water soluble coolant when cutting and drilling. I use a squirt bottle. Your mill may be mini but it will cut through flesh and bone like warm butter... Believe it!
There is so much to learn. If you have access to any applicable adult education programs in your community I strongly erg you to take classes. I am a tool maker with over 30 years of experience and I learn new tricks and tips all the time.
Should you need any assistance (and you will) PM me any time.
$20,000 bushing Dan? lol
...may the good lathe rust in peace *bows head*
Man! that is horribly sad about the lathe. (book idea) Could you imagine what has been made on it over the years and what those parts & pieces ended up doing or effected? Har, really could be a O'henry or King novel. "The evil Lathe" Makes bushings but damns yer soul.... Or a Disney version; "Herbie the love Lathe" A 1960s rockus comedy about a boy and his dreams of becoming a champion machinist and is helped along the way by a lathe that magically comes to life...
