Old 03-18-2014, 07:14 PM
Wheeled Relics Wheeled Relics is offline
Default Custom Aluminum Cylinder Tank Build Input
I am currently working with a manf of go-kart fuel tanks to produce a small run of motorized bicycle cylinder tanks that will fit double-bar design bicycle frames.
My initial design is for a cylinder tank that will fit between a range of straight moto-bike style doublebar and bent-bar frames.
Round Aluminum Tank Tapered Ends
2.75" Dia x 11" Long (fitting between most doublebars)
1.5" Offset Filler
Bottom rear offset down-spout/petcock
I would like some input from the motorized bicycle community on desired specs of tanks of this simple cylinder design to fit in double bar frames. Thank you.
