Old 02-25-2014, 11:55 AM
irishpowerjunkie's Avatar
irishpowerjunkie irishpowerjunkie is offline
Cool Re: Attaching a gas line/tank
Originally Posted by MEASURE TWICE View Post
I looked at the link but did not find specs on what kind of material that is made of. If metal may be OK for gas, but some plastics will melt or soften.
On an associated, but separate issue I even had some clear fuel tubing from an auto parts store soften and the clamp loosen and leak. I rather the neoprene rubber hose that is marine fuel line and seals with those cable clamps real good.
On a search I found this from an auto parts place so maybe in your town can get local also.
measure twice I know from personal experience these are fuel proof and also the one you linked looks like same material , but maybe possible to get better one from motorbike shop if you want to worry about that as certain motorbikes run a dual petcock tank or twin carburetors from one petcock using this, for example a Yamaha virago has a 2 feed petrol pipe from one petcock, i know this from my fathers one out the back.
