Old 02-17-2014, 12:18 PM
Agreen's Avatar
Agreen Agreen is offline
Default Re: Attaching a gas line/tank
Sounds like a poulan chainsaw engine. I have the same one, but never got it to run quite right. My plan was just as Theon said; just run a line from the tank to the carb. The zama carb has a supply and return on it, so you'll need 2 lines most likely. You can use the priming bulb already on the side and run the lines to/from it to the tank.
