Old 01-26-2014, 11:28 AM
lenny9651 lenny9651 is offline
Default Re: n00b With new china motor stumped
i've run into this problem several times, 90% of the time it's the magneto, some dont go bad right away, if you notice the running time between it cutting off getting shorter and shorter then its probably your magneto. you can also try upgrading your plug wire to an 8mm like an accel or mallory and get an ngk plug
