Old 12-27-2008, 08:40 PM
Default Re: Where can I find these?
Walter's right...I'll add a bit.
Ace hardware or any good mom's & pop's hardware store will have 5/16" balls. 5/16" is .312", 8mm is .314". Don't worry about finding 8mm balls, the 5/16" are only .002" smaller and are readily available.
You also want to buy a 1" & a 1-1/4" long 5/16" steel dowel pin to use for the push pin. They are hardened and cheap!
You may get lucky and the 1" pin will work perfectly...otherwise you have to grind the 1-1/4" pin to fit.
