Old 11-03-2013, 08:32 PM
jared8783's Avatar
jared8783 jared8783 is offline
Default 5 hp briggs tricycle, brainstorm ideas
Ok so I bought this like axle with bearing mounts (one bearing bad woop dee doo). Anyways 10" diameter tires with a sprocket attatched. Way I see things I'm a 20" donor bicycle away from being able to make this. Using the headset and forks off the bicycle. I already have the engine sitting around. What would you do with this if you had it?
a square is a rectangle but a rectangle is not a square
