Old 12-24-2008, 10:38 PM
TexasDav's Avatar
TexasDav TexasDav is offline
Default Re: chain and tire problem!
I went to the hardware store and bought enough washers to put 3 flat washers behind the sprocket and between the rubber mount on each bolt (=1/8 in spacing). Then added two thick washers to the axel to prevent the chain from hitting the frame. Worked great and have many miles on it that way.
Always do a pre-ride check. Make it a habit, and ride safe.
