Old 10-31-2013, 02:29 AM
mapbike's Avatar
mapbike mapbike is offline
Default Re: boosting compression? ideas?
Originally Posted by Thunderhead289 View Post
explain that too me, where is the back pressure needed?
I cant bring myself to get one over a shift kit, I just do not care for the look of them even if they are such an improvement. id love to build a motor for best power, though I seriously doubt the bottom end integrity of these motors.
Actually the bottom of these engines does pretty good, the wrist pin/upper bearing is normally the weak spot on these engines when bearing fails its usually that one, sanding the head down flush wont hurt a thing, I've done it multiple times, it will increase compression and give your engine a bit more grunt power and help power even on top end, a well tuned carb and a free flowing exhaust is where to biggest improvement is on a basically stock engine, I will include links to upper bearing which is very good quality.
