Old 12-24-2008, 02:23 PM
2door's Avatar
2door 2door is offline
Default Re: chain and tire problem!
Check your rear sprocket. Some of them (most) have a dished profile. The sprocket teeth are offset to one side. If your sprocket offsets toward the wheel you might get clearance by flipping the sprocket over putting the teeth outboard but watch for seatstay clearance when you do that. If that becomes a problem you might get away with spacing the wheel away from the frame with a couple of washers on the rear axle on the motor drive side.
Good luck, keep us informed. Happy Holidays
