Old 10-14-2013, 08:39 PM
KCvale KCvale is offline
Default Re: replacing the stupid kit throttle
It all depends on what throttle cable you have as unlike every other cable on our motorized bicycles the throttle has a fitting on each end, which means you can't cut the cable and if the length can't be adjusted to give you what is needed on the barrel end (~1") it will be too tight artificially setting idle too high, or too loose so you have a bunch of slop in your throttle action.
Your does not come with a cable so you will have to use yours.
SBP sales one with cable and options for like $19 here.
I've used a couple, they work nice and the pulley it refers to is in the handle.
KC's Krusiers Builds
