Old 10-10-2013, 08:07 PM
maniac57's Avatar
maniac57 maniac57 is offline
Default Re: New Newb Big Time
You can easily adjust chain length by adding shims behind the rear motor mount block.
Just make the chain slightly long and shim till it's right. No tensioner required!
That said, I simply tack weld the tensioner to the frame stay for security on sale builds.
Much easier and still reliable.
