Old 10-07-2013, 04:18 PM
rogergendron1's Avatar
rogergendron1 rogergendron1 is offline
Default Re: list of free mods... or so cheap they could be free...
another cool mod i just saw was the roller clutch ! you can use the clutch cable adjuster bolt hole for a grease hole if you remove it and install a grease fitting where it was !
so looks like i have a new mod to do !
remove clutch cable adjuster screw from case and install a grease fitting for easy lubrication. then make a roller clutch from angle stock and a sliding door wheel.
