Old 12-21-2008, 11:09 PM
erv h erv h is offline
Default Re: A post from an unhappy camper
hi erv h here i just put a gas bike 80 on a schwinn sierra comp looks cool to cold to ride plus 1 foot of snow maybe next week i matched up exhaust port to pipe drilled 4 holes in bottom of pipe moved clip on carb to drop needle i plan on running 24 to1 cci super 2 stroke suzuki oil i also took jet out & put a sowing needle to it & used a o ring from a oil filter to seal carb to manifold should work i couldnt blow air threw fuel valve so i put in the garbage & ordered a motorcycle type & threw away funny looking spark plug & put ngk5hs plug in &new gas line & filter i think it should have a real air filter any ideas k&n were do you get your parts from erv h
