Old 10-06-2013, 02:53 PM
Will122391's Avatar
Will122391 Will122391 is offline
Default Re: clutch cable PLEASE HELP!!
Do not tape down the cable anywhere. Let it hang loose. You can also put wd40 in the cable which helps a lot. Plus you can take off the clutch arm spring. Then you might be able to pull you lever with just 1 finger.
