Old 09-24-2013, 09:14 PM
sniperxfire sniperxfire is offline
Default Re: URGENT - Crank Small Gear HELP
Originally Posted by mapbike View Post
Its common for that gear to set out a bit farther like yours is, what I would do is get you some blue thread locker (loctite) or equivalent, go ahead and remove that screw, put a few drops of the loctite on it and then put it back nice a tight, let it sit over night and you should be good to go.
Cool, i was a little bit worried about that.
Yeh i also thought of using the blue loctite. Ill get it tomorrow.
Thank you so much for your response once again.
