Old 12-19-2008, 11:40 PM
Easy Rider's Avatar
Easy Rider Easy Rider is offline
Santa Cruz Scooter Works
Default Re: what are exhaust springs for?
Originally Posted by misteright1_99 View Post
The benefit would be that the pipe is less likely to break from vibrations
Or crack the cylinder. Also it gives you more options to make your pipe fit better without tweaking the pipe. I've noticed that when I use a pipe without a separate flange or header pipe, either the header pipe or cylinder would crack.
