Old 09-22-2013, 07:11 AM
mapbike's Avatar
mapbike mapbike is offline
Default Re: Building an engine
Originally Posted by Huffydavidson View Post
I sounds like he's talking about the wrist pin clips. Most of us know them as E-clips.
and yes my stars always a line .
After re-reading the post I think you're right, not sure what the 12 o'clock 6 o'clock is for with the wrist pin retainer clips, but it wont hurt anything just the same so that isn't an issue, piston rings placement is though.....
If I had the time I would make a simple straight forward video of installing a complete top end on a lower from start to torquing the head nuts. Someone with a good video camera needs to make a very clear easy to understand video that will walk a noob one step at a time through a correct top end install so we could send them straight to it and they could even use it as a reference throughout the process.
When I get my lower that is on order I may try to do one and see of my camera will shoot it good enough to be used as a tutorial.
