Old 09-13-2013, 11:32 PM
2door's Avatar
2door 2door is offline
Default Re: Too much fuel, not enough air.
If the bike ran good then the problem started the most common cause is trash in the float valve needle and seat.
Another possibility is that the float has a crack in it and it has filled with gasoline and sunk not allowing the needle valve to close which will also cause extreme flooding. Defective floats are also a common problem.
