Old 08-26-2013, 07:48 PM
maniac57's Avatar
maniac57 maniac57 is offline
Default Re: Bushing for clutch arm- sprocket cover???
I've run into this same problem with some of my high-mileage bikes. Keeping the shaft well greased is about all you can do. I looked at options but I agree with 2door, there isn't enough meat in the casting to bush it effectively in my opinion.
But then, I've worn out clutch levers from riding so much!
