Old 08-19-2013, 06:37 PM
crassius crassius is offline
Default Re: X80-BK on a Murray Beach Cruiser - Starting issues and fuel problems. PLEASE HELP
if you are still leaking fuel, then your float is stuck, or has sunk, or is adjusted too high - it not only will not start that way, but will usually fill your motor with fuel so that after fixing the float, you'll still need to blow out the motor
all-in-all a simple problem easy to fix
search here for 'float level'
