Old 08-16-2013, 02:14 PM
nightcruiser nightcruiser is offline
Default Re: Want to get started ASAP in NJ
On the hard pedaling, sounds like your clutch isn't being pulled in fully??? Reason being, compression has nothing to do with manual pedaling, as the clutch should fully disengage the motor from the rear wheel when it is pulled in and locked. If your motor is still turning over with the clutch pulled in (hence your comment about compression) then you either need to adjust your clutch or there is something wrong with the clutch...
