Old 08-15-2013, 06:30 PM
zippinaround zippinaround is offline
Default Re: Painting the motor?
i've painted hundreds of engines from harleys to tractors! if you wanna do it right you should sandblast it first then use two pack paint i.e it comes in two packs 1paint 1chemical hardener.if you just want matt black and wanna do it cheaply i'd sand as much as you can with 180 grit sandpaper then a few light coats of bbq paint or else a matt black etch primer.
