Thread: Dual petcock?
Old 08-11-2013, 10:28 AM
2door's Avatar
2door 2door is offline
Default Re: Dual petcock?
Why not just put a petcock on each tank and then all you'd need is a 'Y' barb fitting to join the two lines to the carburetor. You don't need a 'Y' petcock.
Keep in mind that your rear tank will need to be mounted high enough that the fuel outlet is higher than the carburetor inlet.
