Old 08-09-2013, 03:41 AM
mapbike's Avatar
mapbike mapbike is offline
Originally Posted by bigbutterbean View Post
Good job, mapbike. Anything you can do or learn to do yourself will definitely save you money, with the added benefit of knowing its done the way you want it done, versus paying someone and not always knowing. In the case of making gaskets, its more a sense of knowing the quality of the material you're using, and also being able to port match the gaskets better.
You're 100% correct, the material I used for these gaskets is a high quality material that is resistant to oil, fuel, & water, its easy to work with because it is very fleable but it is also tough enough to stay together and form a nice seal, I sprayed the base gasket with Copper Coat and I always use the Permatex High Tack sealant on my intake gaskets.
