Old 08-06-2013, 07:51 PM
Nashville Kat's Avatar
Default Re: Anyone ever tried putting a pool of oil in the bottom of a China Girl crankcase?
"would be extremely harmful to the performance of the motor.the fuel/oil mix goes from carb and through crankcase on its way to the cylinder,with oil in there,the gas would pick it up and basically flood the cylinder with enough oil it wouldnt run"
Well, you might be right, but I think the fuel mixture actually is just marginally allowed into the crankcase from the carb, through the lesser two ports, and for the purpose of lubricating the bottom end. The main thrust is into the cylinder and then through the exhaust port
