Thread: AMF Roadmaster
Old 07-31-2013, 10:52 PM
mapbike's Avatar
mapbike mapbike is offline
Default Re: AMF Roadmaster
Originally Posted by curtisfox View Post
Yep always made my own to then i saw it here on the forum BINGO.
One can also find one that would fit over the pipe you want to use and then weld the pipe in that way form the back. Do a little taper room for weld, then on a sander to flaten..............Curt
Ill be looking to find one with a hole in it that I can widen to port match to the jug and then Ill find a tubing size that I can heat on that end and create a rectangular shape to match the hole in the flange and then I'll eaitjer braze it are just torch weld with a clothes hanger which works great by the way......
Yep that is a great idea if I can find the size I need .
Tahnks for sharing.
