missle3944
I took mine down for a spin to the bank today
After riding around town with one motorized bicycle buds came home and decided to make a truing stand for my wheels . So I took my original fork from my bike and did some modifications to it so I could chuck it in the vice . Then at lunch while having lunch I sat the about 6 YouTube videos on how to true a bicycle wheels. I just finished secondary back wheel it turns out it's pretty easy. I'll order some spare spokes to have them on hand. No more money for the bike shops. Yea!!!$$
Ken , get an old fork and a couple of zip ties and put them on the fork for point indicators . the videos are easy man .I'm tired of giving my money away .thats 15 or 20 dollars every time towards happy hour .LMAO
	Well, it's back together. The streaks are grooves. I don't think the retaining pin is the problem, because if you look, both are just to the right of the exhaust port. If it were the retaining pin wouldn't it be right on with the transfer port? It just doesn't make sense, engine runs well, no weird noises, has good power. I dunno, maybe when I get a job I'll just replace the top end on it and call it a day. Granted, by that time I'd probably be looking at a complete engine replacement. (dax lower, you know.Are those streaks actually grooves or are they just discolored areas?
The widest mark that goes all the way to top of cylinder could only be caused by something being between piston and cylinder and riding on top of top piston ring at some time or the other, the second streak is in the area that the piston ring retaining pin would be at, if it has worked out of the piston and is rubbing against cylinder wall that is why that mark is likely there.
Might not be a bad idea since your already into it this far to go ahead and pull that jug/cylinder and take a look at the piston ring retaining pin and see if it has worked out against the cylinder wall, if it has I'd get me a new piston asap or you will destroy the engine in time as that groove gets deeper.
if you cant feel a groove with your finger nail then maybe its not an issue but if you can feel a groove you have a problem, my cylinders with 1000-2000 miles on them dont look like that....
Map
Actually if piston wa sin backwards the retaining pin for piston ring would be in that exact spot, got a jug and a piston in front of me now and that is what it shows would be the case, as long as it is running good just run it and if it goes ka-poot..... than you can go from there since you cant change any parts right now, it will probably be fine, just giving you some ideas on what it could be thats causing the grooves, if it is that pin it will get worse until the pin is able to come out and then you will have serious issues more than likely but maybe that wont happen..... fingers crossed for ya bro.
Map
Gotcha now.
I pop the top on my engine every 100 or so miles anyhow, so if anything happens, I'll find it.
Sounds good man...... happy safe riding wishes....!
map
Thanks for the well wises.
As always, my man!Your welcome.... just keep the rubber side down.
map
