Old 07-12-2013, 06:34 PM
KenX KenX is offline
Replaced the 6T (titanium) spark plug with the 7T. Modified frame to exhaust bracing. First got a piece of 1" silicone tube split it and put around bike frame, secured the frame to the expansion pipe with the silicone pressure tape then put a clamp around both on to further secure the exhaust to frame. Overall vibration is less, seem to have got a little kick in power from plug and starts on first pedal stroke instead of second. First time it ever started on first stroke. Was told the 7T plug would assist with starting and vibration. The silicone tape/1" tubing/clamp frame to exhaust bracing initially seems very worthwhile. The tape withstands the heat very well and looks fine.
