Old 07-06-2013, 07:24 PM
maniac57's Avatar
maniac57 maniac57 is offline
Default Re: Fred's (Cr Machine) motor Ordered!
Originally Posted by dumpstercrusher View Post
Im running the dellorto sha carb with a .65mm jet. Im sure i can tune it better but it runs awesome with my expansion chamber. Im running 93 oct and when i had the factory exhaust wit 93 oct i had more four stroking going on until i added the expansion chamber.
As for the record, i bought a 36t sprocket so it should be in next week. Cant wait to see how this motor does with the new sprocket.
Be aware the cheap 36tooth from BGF or LuckEarlyBird will wear out very quickly. Mine is less than two months old and is already wearing enough to cause noise and chain popping. It is too thin and made from soft steel. I will not buy another one from him.
