Old 06-24-2013, 04:53 PM
mdschurtz's Avatar
mdschurtz mdschurtz is offline
Default Re: Howdy From Greenville, NC
ok So I have semi fixed the issue. I adjusted the throttle and clutch cable and made sure there was no air leaks in the carb to intake. now the bike will go full throttle but when it starts getting into the higher RPMs it just kind of dies off. like it's too rich or too lean, the problem is my adjuster screw on the outside of the carb really doesn't do anything for me. should I adjust the jet? if so do I just need to remove the bowl to access the jet?
