Thread: newbie question
Old 06-02-2013, 08:34 PM
maniac57's Avatar
maniac57 maniac57 is offline
Default Re: newbie question
I remove the cylinder and rinse out the crankcase to remove debris before I install the kits. If you are careful not to tear the base gasket, you should not need new gaskets. The head gasket is re-useable
