Old 05-28-2013, 04:32 PM
577-Jersey's Avatar
577-Jersey 577-Jersey is offline
Originally Posted by maniac57 View Post
Finally swapped to the new 36 tooth rear sprocket on The Pig.
Had to shorten the chain and redo the tensioner to get things aligned again.
Used my usual trick to break the chain as you can see to the left of the tensioner. The spot welds are barely visible where I broke the chain.
I am glad I finally swapped to the 36. It calms the bike down just right and still gives good cruising at lower speeds which make the motor happier.
I expect slightly better mileage too but we shall see...
Nice Maniac!!
My bike goes 32 MPH with a 44 tooth WOT wound out tight,,,it cruises nice at 20-24,,will the 36 tooth allow me to cruise at 25-28,, what is your top speed now,,35,,and how is she on the hills???
My 44 pulls me up the steepest hills around here no pedal at all.
Good times....
Ghost pedaling in NJ....
