Old 05-27-2013, 11:33 AM
KCvale KCvale is offline
Default Re: Two items that could save your life
Originally Posted by karryhunt View Post
If you want to eliminate 90% of your build problems these two items are a must
Hub adapter with sprocket
Kip Springer chain tensioner
Yes these two items cost nearly as much as the entire kit but the amount of headaches it will save you in the end will greatly out weigh the cost.
It solved 90% of YOUR build problems, thanks for sharing your solution.
90% of my build 'problems' are solved with an SBP front motor mount and a dual pull brake lever for $25.
KC's Krusiers Builds
