Old 05-10-2013, 08:36 AM
577-Jersey's Avatar
577-Jersey 577-Jersey is offline
Originally Posted by CTripps View Post
Pulled the carb off the cruiser and pulled it apart, trying to set the float level without it flooding and dribbling gas everywhere. It took a few tries, but I think I've got it now. Next will be to pull the exhaust and see if it's a bad weld or a bad gasket causing it to develop black drips at the engine. I just can't tell for sure which side of the flange the drip is forming from (engine or pipe).
So far I've set all my float levels(tangs) about 3/32(about 2.5 mm) from where gasket seats,,or bottom of the carb housing and they run great with no leaks.Last kit I got the float level was way too low so I bent the tangs up before I even tried to start it for the first time.Ive read somewhere around here that guys set them even a little closer like 1/16th.that seems a little to high too me,,plenty of fuel in the bowl the way I do it.
Good Times...
Ghost pedaling in NJ....
