sboricic123
This happened to me last week. I ran out of gas on my 2 stroke and had to peddle home with the clutch in the lock position about 3-4 kms. I was wondering if that is hard on the clutch.
No. The clutch, if properly adjusted will completely disengage and pedaling the bike will not harm it in any way. In fact the basic idea of the manual clutch is to allow the bike to be pedaled normally with only a little parasitic drag from the chain, sprockets and clutch cross shaft. You're good to go. No damage.
As long as your chain alignment and tension are good, coasting with the clutch disengaged won't hurt anything. When the clutch is disengaged the only moving parts of the engine is the drive sprocket and the clutch cross shaft. The crankshaft, piston and the gears on the right side don't move. Of course you need to assure that when you pull the clutch lever in and lock it that it is completely disengaging the clutch. That's part of clutch cable adjustment.I was wondering something, does it matter how fast you go? I live in the mountains and often times I will hold in the clutch lever, kill the engine, and glide down the hills. I can reach speeds up to 40+ miles per hour gliding down these long steep hills with the engine off. With the sprocket spinning that fast without the engine running and oil flowing could it damage the clutch or engine? Should I put extra grease on the clutch or anywhere else?
There's no need for extra lubrication but the chain does need it, coasting, pedaling or under engine power the chain needs lube.
Be sure to keep the bucking bar and ball well greased and you should have no issues with coasting.
