Old 12-02-2008, 06:21 PM
thatsdax thatsdax is offline
Default Re: 2 min. and 100 ft
If you have the wires bass akwards on the CDI that will put timing of the spark 180 degrees off. If you have a weak spark that you can see, it will no longer spark under compression. If you have a strong spark and still no joy, then it is a fuel issue. Disconnect your fuel line from the carb and drip some fuel directly into the cylinder by removing the spark plug. When you pull your plug might as well do a plug chop which means pull the plug and look at the tip. Is it wet? Dry? Black ? Brown? If it is dry, then drip some fuel into the cylinder, replace the plug and see if she fires and runs for a few seconds or at least pops. Let us know. Thanks..
