Old 12-01-2008, 06:16 PM
cliff880 cliff880 is offline
Default Re: Drive chain sprocket
Originally Posted by cliff880 View Post
Al I'll check out the grinding idea,guess I'll have to remove the drive sprocket first then use a dremel.
Al,I used the dremel and ground the small flange behind the drive sprocket and although not perfect it seems to work alot better,I'll finish it tomorrow,I've learned to walk away sometimes Cliff880
