Old 12-01-2008, 09:00 AM
cliff880 cliff880 is offline
Default Re: Drive chain sprocket
Originally Posted by Allan View Post
I've had the same problem. If the chain is rubbing against housing you need to grind down housing a little. It may also be rubbing against housing because the teeth on the sprocket are not seated. Lay your chain on a flat surface, take your sproket and roll it down the chain. If it pulls the chain up, grind the corners off the teeth a little. Do this until the sproket runs freely through the chain.
Al I'll check out the grinding idea,guess I'll have to remove the drive sprocket first then use a dremel.
