Old 04-15-2013, 06:08 PM
MotorBicycleRacing's Avatar
MotorBicycleRacing MotorBicycleRacing is offline
Default Re: What is this part!?
Originally Posted by Outraaageous View Post
Thanks for a fast reply!! Then ill have to attach my peg via the two holes closest to the center of the flywheel. Any ideas how to do that? The peg is actually wider than the gap between the holes, and ive run out of ideas
What diameter is your peg or friction drive spindle?
What size, cc and hp does your motor have?
Too large of a diameter will be too high of a gear ratio.
Also what terrain are you riding on, hills? flat?
Your weight might be a factor too.
